Multitimer defect ?
CSH
Astra-G: 2.2 DTi Sport
Beitrag Verfasst am: Di 09 Feb, 2010 12:15 am    Titel: Multitimer defect ? Nach oben
Hi
I'm getting some electrical "ghosts" in the Astra.
First of, when I turn on the turningsignal (blinker), the symbol for trailer is flashing once - and only once, while the normal symbol for turningsignal is working as it should. When I look at the wiring diagram it seems that, that symbol is controlled by the multitimer, and not going through any relay.
A couple of times every year, my radio (ncdr1100) reboots, and will not work with the remote on the steeringwheel, or reacting when pressing the buttons on the radio.
Next thing is, my ECC will not start, it's refilled, new condensator, every fuse has been checked, the compressor has been measured and is fine.. but we cannot measure any voltage in the plug when trying to activate the compressor.
How much of these failures are controlled by the multitimer, or am I looking at 3 different failures ?
NMWeb.dk
Benutzer-Profile anzeigenPrivate Nachricht sendenWebsite dieses Benutzers besuchenGalerie dieses Benutzers besuchenMSN Messenger
eraser216
Astra-G: 1.8 16V CC 5-Türer Elegance (X18XE1)
Beitrag Verfasst am: Di 09 Feb, 2010 1:31 am    Titel: Nach oben
Hi CSH welcome to astra4ever.net
Multitimer:
I think you've got three different failures because the ECC and the radio have nothing to do with the multitimer. The multitimer only controls the turning signals, wipers, the interior light and some other things like that. But unfortunatly i have absolutely no idea whats wrong. Do you have a trailer coupling?
ECC:
I think your ECC maybe has a broken wire somewhere so the compressor gets no activation signal. That's the only thing that i can imagine because you have checked everything else.
Radio:
Maybe the radio has some broken soldering connections. What do you have to do to get the radio back to work? Do you have to move it or to hit it? That would be a typical symptom for broken soldering connections.
I hope I could help a little bit and you can understand me. I don't have written in english for a few years.
Greetings!
eraser216
denn ich bin die absolut gemeinste Drecksau in diesem verdammten Tal! Twisted Evil
Mein TV
CSH
Beitrag Verfasst am: Di 09 Feb, 2010 8:04 am    Titel: Nach oben
eraser216 hat folgendes geschrieben::
Multitimer:
ECC:
Radio:
Greetings!
eraser216
Your english works perfect for me Smile
I've been here for a while, but only in the gallery section Smile
Ok.. so the turningsignal failure is caused by the multitimer as I was expecting ? I used to have a trailercoupling, but I removed it completely as I wasn't using it - and it had to go because of the OPC2 rearbumper Smile
And I remembered to remove the fuse as well.
The radio works perfectly again if I turn of the car, and back on.. so it could be a bad connection I guess..
About the ECC.. we're thinking that the coolingmodule has a bad connection, as it controls the ECC as well.. but when I looked in the wiringdiagram I noticed that a few connections for the ECC went through the multitimer as well, and thought that it might be something with that as well..
Funky thing though is, that if we use the Tech2, we can connect to the ECC and it returns with no failures.
That car is giving me more and more grey hairs sometimes..
NMWeb.dk
eraser216
Beitrag Verfasst am: Di 09 Feb, 2010 5:07 pm    Titel: Nach oben
Hm do you still have the plug for the trailer somewhere in the back? Maybe this causes your turning signal problem.
I'm at the end of my knowledge, I hope someone with more experience can help you.
Mein TV
CSH
Beitrag Verfasst am: Di 09 Feb, 2010 11:03 pm    Titel: Nach oben
Only the original that is in the wiring - I removed everything else that had to do with the trailer.
NMWeb.dk
